[GRASS-dev] [GRASS GIS] #1683: error message v.add.col on MacOSX
GRASS GIS trac at osgeo.org
Tue Aug 14 02:57:00 PDT 2012
 Reporter:  jradinger      |       Owner:  grass-dev@…
     Type:  defect         |      Status:  new
 Priority:  major          |   Milestone:  6.4.3
Component:  Shell Scripts  |     Version:  svn-develbranch6
 Keywords:  v.db.addcol    |    Platform:  All
      Cpu:  Unspecified    |
Comment(by jradinger):
 I tried again with the first example (streams at test). No problems occured.
 Anyway another
 mapset still produces error messages:
 (Tue Aug 14 12:46:01 2012)
 v.db.addcol map=sender_point at FIDIMO_Cele columns=testcol DOUBLE
 /usr/local/grass-6.5.svn/scripts/v.db.addcol: 1: eval:
 FIDIMO_Cele: not found
 (Tue Aug 14 12:46:02 2012) Command finished (1 sec)
 And here the extended output:
 (Tue Aug 14 12:48:12 2012)
 + [ -z /usr/local/grass-6.5.svn ]
 + [ map=sender_point at FIDIMO_Cele != @ARGS_PARSED@ ]
 + basename /usr/local/grass-6.5.svn/scripts/v.db.addcol
 + CMDLINE=v.db.addcol
 + CMDLINE=v.db.addcol "map=sender_point at FIDIMO_Cele"
 "columns=testcol DOUBLE"
 + export CMDLINE
 + exec g.parser /usr/local/grass-6.5.svn/scripts/v.db.addcol
 + [ @ARGS_PARSED@ != @ARGS_PARSED@ ]
 + PROG=v.db.addcol
 + which awk
 + [ ! -x /usr/bin/awk ]
 + unset LC_ALL
 + LC_NUMERIC=C
 + export LC_NUMERIC
 + g.gisenv get=MAPSET
 + eval FIDIMO_Cele
 + FIDIMO_Cele
 + g.findfile element=vector file=sender_point at FIDIMO_Cele
 mapset=
 + eval name='sender_point at FIDIMO_Cele' mapset='FIDIMO_Cele'
 fullname='sender_point at FIDIMO_Cele' file='/home/radinger/Doc
 uments/GRASS_locations/Cele_location/FIDIMO_Cele/vector/send
 er_point'
 + name=sender_point at FIDIMO_Cele mapset=FIDIMO_Cele
 fullname=sender_point at FIDIMO_Cele file=/home/radinger/Docume
 nts/GRASS_locations/Cele_location/FIDIMO_Cele/vector/sender_
 point
 + [ ! /home/radinger/Documents/GRASS_locations/Cele_location
 /FIDIMO_Cele/vector/sender_point ]
 + v.db.connect sender_point at FIDIMO_Cele -gl layer=1 fs=|
 + cut -f2 -d|
 + table=sender_point
 + [ -z sender_point ]
 + cut -f4 -d|
 + v.db.connect sender_point at FIDIMO_Cele -gl fs=| layer=1
 + database=/home/radinger/Documents/GRASS_locations/Cele_loc
 ation/FIDIMO_Cele/sqlite.db
 + cut -f5 -d|
 + driver=sqlite
 + awk -F, {print NF}
 + echo testcol DOUBLE
 + colnum=1
 + n=1
 + [ 1 -le 1 ]
 + cut -d, -f1
 + col=testcol DOUBLE
 + [ -z testcol DOUBLE ]
 + db.execute database=/home/radinger/Documents/GRASS_locatio
 ns/Cele_location/FIDIMO_Cele/sqlite.db driver=sqlite
 + echo ALTER TABLE sender_point ADD COLUMN testcol DOUBLE
 + [ 0 -eq 1 ]
 + expr 1 + 1
 + n=2
 + [ 2 -le 1 ]
 + v.support sender_point at FIDIMO_Cele cmdhist=v.db.addcol
 "map=sender_point at FIDIMO_Cele" "columns=testcol DOUBLE"
 + exit 0
 (Tue Aug 14 12:48:13 2012) Command finished (1 sec)
 So far as I can see there is no whitespace in the mapset.
 Tested on Ubuntu 12.04 with Grass6-devel r52671. This might
 be related to ticket #1696.
 /johannes
Ticket URL: <http://trac.osgeo.org/grass/ticket/1683#comment:9>
