[GRASS-dev] WinGRASS 6.4.3/6.5 binary???
Martin Landa landa.martin at gmail.com
Wed Aug 15 14:23:25 PDT 2012
2012/8/15 Helena Mitasova <hmitaso at ncsu.edu>:
> thanks for the quick answer about WinGRASS6.4.2-2, here is a related question
> - would it be possible to post a WinGRASS6.5 snapshot (even if it is not daily)?
> I am in a similar situation as Michael and although I plan to use mostly 6.4.2, I would like to show the students some new features
> available in GRASS6.5, especially wxnviz (and they can do some testing along the way),
available from [1] (broken at this moment, I will try to fix it ASAP).
You could probably use also 6.4.3 [2] (?)
Best regards, Martin
[1] http://wingrass.fsv.cvut.cz/grass65/
[2] http://wingrass.fsv.cvut.cz/grass64/
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
