[GRASS-dev] Proposal for setting up of new locations in wxGUI
Margherita Di Leo
dileomargherita at gmail.com
Thu Aug 16 08:43:10 PDT 2012
On Thu, Aug 16, 2012 at 4:55 PM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> I would like to suggest a modification (even for G6) for the
> Location Wizard:
> When defining a new location from an existing dataset (like SHAPE
> or GeoTIFF with proper metadata), it creates the location and then
> brings you back to the original startup screen, then you can "login"
> into GRASS. But.. no maps there. So (new) users will be confused.
> Change proposal:
> Before reaching the startup screen again, ask if to import the map
> which has been used for creating the location. Yes: do it; no: return
> to startup screen.
> What do you think?
+1 definitely.
Thanks!
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Dr. Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120816/65f882d0/attachment.html>
