[GRASS-dev] Excel read support
Volker Froehlich
volker27 at gmx.at
Thu Aug 16 10:43:37 PDT 2012
On Thu, 2012-08-16 at 19:38 +0200, Markus Neteler wrote:
> Hi,
> since Excel files continue to be widely used, it would be a great help to
> have direct read support in GRASS, e.g. for easy table joins.
> I have found this library (which comes e.g. with Fedora as well as OSGeo4W):
> https://github.com/python-excel/xlwt
> (main page: http://www.python-excel.org/)
> To always go through LibreOffice conversion or other tricks is a bit annoying...
> Or am I missing an easy trick?
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Fedora also has Furieri's freexl, in case that helps.
Volker
