[GRASS-dev] [GRASS GIS] #1452: wx location wizard doesn't ask for datum transform options because proj4 4.7.1's epsg file is broken
trac at osgeo.org
Sun Aug 19 04:16:11 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: location wizard, g.proj | Platform: All
Cpu: All |
Comment(by neteler):
Replying to [comment:1 martinl]:
> Replying to [ticket:1452 hamish]:
> > example: proj=nzmg datum=nzgd49 should give you 3 choices.
> > same trouble if you go by epsg code <27200>.
> > on linux it works. related to #1189?
> are you sure that it works on GNU/Linux, testing G65
> g.proj epsg=27200 datumtrans=-1
> gives no output.
No result either in GRASS 6.4.svn (if there should be any).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1452#comment:14>
