[GRASS-dev] [GRASS GIS] #391: SQLite driver doesn't complain enough with stupid mistakes
GRASS GIS trac at osgeo.org
Sun Aug 19 15:40:08 PDT 2012
  Reporter:  hamish    |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  major     |   Milestone:  6.4.0
 Component:  Database  |     Version:  svn-develbranch6
Resolution:  fixed     |    Keywords:  sqlite
  Platform:  Linux     |         Cpu:  Unspecified
Changes (by neteler):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 The intentionally broken command (missing comma) from the original
 ticket is no longer accepted:
 GRASS 6.4.3svn (spearfish60):~ > v.db.addcol tmp_arch column='x double y
 double'
 DBMI-SQLite driver error:
 Error in sqlite3_prepare():
 duplicate column name: x
 ERROR: Error while executing: 'ALTER TABLE tmp_arch ADD COLUMN x double y
        double
 ERROR: Cannot continue (problem adding column).
 Hence the ticket can be closed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/391#comment:5>
