[GRASS-dev] Empty default answer
Markus Neteler
neteler at osgeo.org
Mon Aug 20 01:29:59 PDT 2012
On Tue, Aug 14, 2012 at 2:52 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> Is it correct leave empty a default answer in a module?
> An example is in r.out.pov with zmod or objmod option
(it is about v.out.pov):
http://grass.osgeo.org/grass64/manuals/html64_user/v.out.pov.html
I think that the empty ("") answers in
grass64/vector/v.out.pov/main.c
58 zmod_opt = G_define_option();
59 zmod_opt->key = "zmod";
60 zmod_opt->type = TYPE_STRING;
61 zmod_opt->required = NO;
62 zmod_opt->answer = "";
63 zmod_opt->description =
64 "Modifier for z coordinates, this string is appended
to each z coordinate.\n"
65 "\t\tExamples: '*10', '+1000', '*10+100', '*exaggeration'";
66 objmod_opt = G_define_option();
67 objmod_opt->key = "objmod";
68 objmod_opt->type = TYPE_STRING;
69 objmod_opt->required = NO;
70 objmod_opt->answer = "";
71 objmod_opt->description =
72 "Object modifier (OBJECT_MODIFIER in POV-Ray documentation).\n"
73 "\t\tExample: \"pigment { color red 0 green 1 blue 0 }\"";
should be removed.
Markus
