[GRASS-dev] [GRASS GIS] #1607: WXGUI regression - attribute query fails to display text attribute values
trac at osgeo.org
Mon Aug 20 01:56:50 PDT 2012
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:1 neteler]:
> Do you have a sample map to test?
Here You go. Just create a location and import attached file. Compare
output of 6.4.0 and 6.4.x current on the same file.
The idea of setting encoding in a GUI preferences is flawed by design. I
routinely deal with datasets in different encodings (map1 - utf-8; map2 -
ISO-8859-13; etc.). Still this is a change that needs to be done in GRASS
7 to allow specifying encoding for each vector dataset/layer(?)
separately.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1607#comment:2>
