[GRASS-dev] [GRASS GIS] #1607: WXGUI regression - attribute query fails to display text attribute values
trac at osgeo.org
Mon Aug 20 02:22:12 PDT 2012
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2
Keywords: query | Platform: Unspecified
Cpu: Unspecified |
Changes (by neteler):
* keywords: => query
Comment:
Yes, confirmed.
OGR can decipher it:
ogrinfo grass_encoding.shp grass_encoding
INFO: Open of `grass_encoding.shp'
using driver `ESRI Shapefile' successful.
Layer name: grass_encoding
Geometry: Point
Feature Count: 2
Extent: (490813.154373, 280495.272002) - (516942.353107, 284572.168258)
Layer SRS WKT:
PROJCS["LKS92_Latvia_TM",
GEOGCS["GCS_LKS92",
DATUM["Latvia_1992",
SPHEROID["GRS_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",24],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",-6000000],
UNIT["Meter",1]]
nosaukums: String (80.0)
OGRFeature(grass_encoding):0
id (Integer) = (null)
nosaukums (String) = âðòï
POINT (490813.154373089957517 284572.168258102843538)
OGRFeature(grass_encoding):1
nosaukums (String) = çèþì
POINT (516942.35310710943304 280495.272001731034834)
while GRASS' wxGUI query tool cannot giving the indicated error.
Also the Tcl/TK form fails: "nosaukums : âðòï "
Ticket URL: <http://trac.osgeo.org/grass/ticket/1607#comment:3>
