[GRASS-dev] [GRASS GIS] #963: wxGUI: frequent Pango-CRITICAL errors
GRASS GIS trac at osgeo.org
Mon Aug 20 05:46:33 PDT 2012
  Reporter:  msieczka  |       Owner:  grass-dev@…
      Type:  defect    |      Status:  closed
  Priority:  normal    |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-releasebranch64
Resolution:  wontfix   |    Keywords:
  Platform:  Linux     |         Cpu:  x86-64
Changes (by neteler):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 From grass-dev ML:
 On Tue, Mar 13, 2012 at 8:29 AM, Glynn Clements wrote:
 > We can't always get rid of such warnings, as some of them are due to
 > the way that wxWidgets uses the underlying toolkit (GTK+ on Linux).
 > The GTK+ libraries (GTK, GDK, GLib and Pango) are known for being
 > rather "noisy" (i.e. generating many warning/error messages). This is
 > mainly to help developers identify bugs; having detected an error, the
 > libraries will normally try to recover from it, but in the case of
 > GRASS such bugs may be in the wxWidgets or wxPython layers rather than
 > in GRASS itself.
 > The messages should only be of concern to the user if they correlate
 > with the GUI failing to work.
Ticket URL: <http://trac.osgeo.org/grass/ticket/963#comment:1>
