[GRASS-dev] [GRASS GIS] #1615: Regression - v.transform fails to create a 3D map, crashes on Windows
trac at osgeo.org
Mon Aug 20 06:05:38 PDT 2012
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.3
Component: Vector | Version: 6.4.2
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:2 marisn]:
> It doesn't crash any more, as there have been some DBF related fixes,
still produced output is wrong -> it doesn't shift on Z axis, as it was
doing in 6.4.0.
> v.random output=rm_a_map n=10 zmax=100.0 column='h double precision'
> v.transform input=rm_a_map output=rm_a_map3d table=rm_a_map
columns=zshift:h
> v.info map=rm_a_map3d
tested here with the latest osgeo4w-wingrass6.4.3svn on a win7-64bit-box
in the nc-sample dataset:
v.random output=rm_a_map2 n=10 zmax=100.0 column=h
v.transform --verbose input=rm_a_map at user1 output=rm_a_map3d
table=rm_a_map column="zshift:h"
v.transform crashes, but rm_a_map3d - although corrupted - is created and
3d
corrputed rm_a_map3d
v.build --verbose map=rm_a_map3d at user1
Coor-Datei der Vektorkarte <rm_a_map3d at user1> ist größer als sie sein
sollte (304 Byte zuviel).
but 3d
v.info
Layer: rm_a_map3d at user1
Karte ist 3D: Yes
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1615#comment:3>
