[GRASS-dev] [GRASS GIS] #1339: Corrupted Shapefile causes buffer overflows, assetions etc.
trac at osgeo.org
Mon Aug 20 15:33:41 PDT 2012
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: Vector | Version: svn-releasebranch64
Keywords: rtree | Platform: Unspecified
Cpu: Unspecified |
Changes (by neteler):
* version: unspecified => svn-releasebranch64
* milestone: 6.4.2 => 6.4.3
Comment:
I imported the attached file into GRASS 70: v.in.ogr worked. Then I tried
v.out.ascii augstumpunkti1
*** glibc detected *** v.out.ascii: realloc(): invalid next size:
0x0000000001409a00 ***
It crashes in GRASS 7.svn r52794 in lib/vector/Vlib/ascii.c, line 529
(G_rasprintf())
Import with 6.4.svn still fails:
GRASS 6.4.3svn (PERMANENT):/tmp/broken_shapefile > v.in.ogr
augstumpunkti1.shp out=augstumpunkti1 --o
WARNING: Datum <Not_specified_based_on_GRS_1980_ellipsoid> not recognised
by GRASS and no parameters found
Projection of input dataset and current location appear to match
WARNING: Vector map <augstumpunkti1> already exists and will be
overwritten
Layer: augstumpunkti1
Counting polygons for 60 features...
Importing map 60 features...
100%
Building topology for vector map <augstumpunkti1_tmp>...
Registering primitives...
v.in.ogr: split_q.c:69: RTreeClassify: Assertion `!p->taken[i]' failed.
Aborted (core dumped)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1339#comment:2>
