[GRASS-dev] [GRASS GIS] #312: wxNVIZ prints debug to terminal
trac at osgeo.org
Tue Aug 21 03:54:30 PDT 2012
Reporter: msieczka | Owner: grass-dev@…
Type: defect | Status: new
Priority: minor | Milestone: 6.4.3
Component: wxGUI | Version: svn-releasebranch64
Keywords: digitizer | Platform: All
Cpu: All |
Changes (by neteler):
* keywords: => digitizer
* version: svn-develbranch6 => svn-releasebranch64
* milestone: 6.4.0 => 6.4.3
Comment:
This is still an issue for the wxdigitizer (not debug but suer
messages):
GRASS 6.4.3svn (nc_spm_08):~ >
GRASS_INFO_PERCENT: 0
GRASS_INFO_PERCENT: 100
GRASS_INFO_PERCENT: 12
GRASS_INFO_PERCENT: 25
GRASS_INFO_PERCENT: 37
GRASS_INFO_PERCENT: 50
GRASS_INFO_PERCENT: 62
GRASS_INFO_PERCENT: 75
GRASS_INFO_PERCENT: 87
GRASS_INFO_MESSAGE(10737,1): Building topology for vector map <ciao>...
GRASS_INFO_END(10737,1)
GRASS_INFO_MESSAGE(10737,2): Registering primitives...
GRASS_INFO_END(10737,2)
GRASS_INFO_MESSAGE(10737,3): 6 primitives registered
GRASS_INFO_END(10737,3)
GRASS_INFO_MESSAGE(10737,4): 18 vertices registered
GRASS_INFO_END(10737,4)
GRASS_INFO_MESSAGE(10737,5): Building areas...
GRASS_INFO_END(10737,5)
GRASS_INFO_PERCENT: 16
GRASS_INFO_PERCENT: 33
GRASS_INFO_PERCENT: 66
GRASS_INFO_PERCENT: 83
GRASS_INFO_MESSAGE(10737,6): 3 areas built
GRASS_INFO_END(10737,6)
GRASS_INFO_MESSAGE(10737,7): 1 isles built
GRASS_INFO_END(10737,7)
GRASS_INFO_MESSAGE(10737,8): Attaching islands...
GRASS_INFO_END(10737,8)
GRASS_INFO_MESSAGE(10737,9): Attaching centroids...
GRASS_INFO_END(10737,9)
GRASS_INFO_MESSAGE(10737,10): Number of nodes: 4
GRASS_INFO_END(10737,10)
GRASS_INFO_MESSAGE(10737,11): Number of primitives: 6
GRASS_INFO_END(10737,11)
GRASS_INFO_MESSAGE(10737,12): Number of points: 0
GRASS_INFO_END(10737,12)
GRASS_INFO_MESSAGE(10737,13): Number of lines: 0
GRASS_INFO_END(10737,13)
GRASS_INFO_MESSAGE(10737,14): Number of boundaries: 6
GRASS_INFO_END(10737,14)
GRASS_INFO_MESSAGE(10737,15): Number of centroids: 0
GRASS_INFO_END(10737,15)
GRASS_INFO_MESSAGE(10737,16): Number of areas: 3
GRASS_INFO_END(10737,16)
GRASS_INFO_MESSAGE(10737,17): Number of isles: 1
GRASS_INFO_END(10737,17)
GRASS_INFO_MESSAGE(10737,18): Number of areas without centroid: 3
GRASS_INFO_END(10737,18)
Ticket URL: <http://trac.osgeo.org/grass/ticket/312#comment:1>
