[GRASS-dev] [GRASS GIS] #970: r.report seg faults on small page width values
GRASS GIS trac at osgeo.org
Tue Aug 21 06:47:29 PDT 2012
 Reporter:  epatton                                   |       Owner:  grass-dev@…
     Type:  defect                                    |      Status:  new
 Priority:  minor                                     |   Milestone:  6.4.4
Component:  Raster                                    |     Version:  svn-develbranch6
 Keywords:  r.report, page width, segmentation fault  |    Platform:  Linux
      Cpu:  x86-64                                    |
Changes (by neteler):
  * milestone:  6.4.0 => 6.4.4
Old description:
> r.report seg faults when passed small values of page width values. From
> the NC test dataset, the elevation raster creates the seg fault on 23
> characters, and an infinite loop with 24 characters:
> r.report -h map=elevation pw=23
>  100%
> |Category Information |
> |                    #|description                                  |
> |104.966573-105.361675|from  to �
> '@�?@�h0�h��h`�h@�h�����'�Yc4@/�~F�'@4@���V
>       Al
>         A at k#A�K#A�?�����Segmentation fault
> gdb backtrace:
> gdb -q r.report
> Reading symbols from /usr/local/grass-6.5.svn/bin/r.report...done.
> (gdb) run map=elevation pw=23
> # lots of binary gibberish printed, then:
> Program received signal SIGSEGV, Segmentation fault.
> print_label (s=0x629000 <Address 0x629000 out of bounds>, len=<value
> optimized out>, pflag=1, spacing=0, dot=<value optimized out>) at
> label.c:46
> 46                  putchar(*s);
> (gdb)
> ~ Eric.
New description:
  100%
 |                    #|description                                  |
       Al
 gdb backtrace:
 gdb -q r.report
 label.c:46
 46                  putchar(*s);
 (gdb)
 ~ Eric.
Comment:
 Still segfaulting:
 GRASS 6.4.3svn (nc_spm_08):~ > r.report -h map=elevation pw=23
  100%
 |                    #|description                                  |
 |103.781266-104.176368|from  to ��������c�?�?�?�?�?p�
 A�
 Segmentation fault (core dumped)
 also in GRASS 7.svn:
 GRASS 7.0.svn (nc_spm_08):~ > r.report -h map=elevation pw=23
  100%
 |                    #|description                                  |
 A�
 A0�#A�z#A�?�:�:G�����:n@� �:@�:`�:Segmentation fault (core dumped)
Ticket URL: <http://trac.osgeo.org/grass/ticket/970#comment:3>
