[GRASS-dev] [GRASS GIS] #1565: wxGUI: command console with no map display open causes error
GRASS GIS trac at osgeo.org
Tue Aug 21 08:13:00 PDT 2012
  Reporter:  hamish  |       Owner:  grass-dev@…
      Type:  defect  |      Status:  closed
  Priority:  minor   |   Milestone:  6.4.3
 Component:  wxGUI   |     Version:  svn-releasebranch64
Resolution:  fixed   |    Keywords:  command console
  Platform:  Linux   |         Cpu:  x86-64
Changes (by annakrat):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Fixed in r52818, r52819, r52820, however this is a common problem which
 should be solved later by refactoring.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1565#comment:2>
