[GRASS-dev] [GRASS GIS] #1702: column selector for v.distance in wxGUI doesn't work
trac at osgeo.org
Tue Aug 21 10:10:37 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: unspecified
Keywords: column select | Platform: Unspecified
Cpu: Unspecified |
The column selector drop down for v.distance in the GUI dialog does not
work. The same problem happens on a couple other modules, probably for the
same reason.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1702>
