[GRASS-dev] [GRASS GIS] #1106: r.terraflow limited to 32bit temp files in WinGrass
trac at osgeo.org
Tue Aug 21 13:12:26 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: task | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-develbranch6
Resolution: fixed | Keywords: wingrass, r.terraflow
Platform: MSWindows XP | Cpu: x86-32
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
* milestone: 6.4.1 => 7.0.0
Comment:
Replying to [comment:2 mmetz]:
> Replying to [ticket:1106 hamish]:
> > The ftell() solution is not 64bit safe though, so it awaits a backport
of G_ftell() [or even better `off_t G_filesize()`] in some later release.
Why backport working solutions instead of releasing working solutions?
> AFAICT this will only work if LFS is globally enabled/disabled in grass,
as in grass7. The modifications done in grass7 are probably too
fundamental to backport (not sure about libgis and the raster part, but
for the vector part I had to change core functions in the vector libs).
That would require backporting core parts of trunk. This won't be fixed
for GRASS 6 and has been fixed some time ago for GRASS 7.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1106#comment:3>
