[GRASS-dev] [GRASS GIS] #580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
GRASS GIS trac at osgeo.org
Wed Aug 22 02:59:00 PDT 2012
  Reporter:  hamish        |       Owner:  grass-dev@…
      Type:  defect        |      Status:  reopened
  Priority:  blocker       |   Milestone:  7.0.0
 Component:  wxGUI         |     Version:  svn-trunk
Resolution:                |    Keywords:  wingrass
  Platform:  MSWindows XP  |         Cpu:  Unspecified
Comment(by mmetz):
 Replying to [comment:46 hellik]:
 > Replying to [comment:45 mmetz]:
 > > Which ones are known to the system? You can check in Systemsteuerung
 -> Software or similar. Maybe only the one of ArcGIS10?
 C:\Users\xxxx>echo %PATHEXT%
 .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
 > and a screenshot of standard software related to python added.
 I was rather interested about how many different python versions are in
 the list of installed software as known by the system. The list .py* file
 extensions does not give the full path to the python.exe being used, i.e.
 which one of the 6 python.exe's on your system will be used.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/580#comment:47>
