[GRASS-dev] [GRASS GIS] #580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
trac at osgeo.org
Wed Aug 22 04:57:50 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment(by glynn):
Replying to [comment:43 mmetz]:
> WinGRASS does not install python, nor numpy, scipy, or wxpython. These
are all bundled with wingrass but not installed the Windows way. Therefore
the system does not know that there is something like python.exe and the
system does not know what to do with .py files. IIRC, a decision was made
some time ago to not install python the Windows way together with wingrass
because that could interfere with already installed python versions.
Correct. WinGRASS should assume Python, the same way that it does on
Linux. On Linux, we don't install Python, we just assume that
"#!/usr/bin/env python" will invoke a suitable Python interpreter. Windows
doesn't use a shebang, it uses extensions, so on Windows, the assumption
should be that the .py extension is associated with a suitable Python
interpreter.
> WinGRASS is currently compiled against osgeo4w python and related
packages,
WinGRASS isn't "compiled" against any version of Python.
> > Adding .PY to the PATHEXT environment variable allows Python scripts
to be run without the extension (in the same way as .bat, .cmd, etc). That
will work for anything which uses the shell (system(), Python's subprocess
module, batch files, etc).
> Even if the system knows nothing about any python.exe?
If the .py extension hasn't been associated with a Python interpreter,
executing Python scripts won't work, with or with the .py extension.
If we don't want to spend the rest of our lives adding one hack after
another to deal with Python scripts on Windows, "executing" a Python
script (via !CreateProcess(), system(), subprocess.Popen() or whatever)
has to just work, which requires that the .py extension is associated with
a working Python interpreter.
Ticket URL: <https://trac.osgeo.org/grass/ticket/580#comment:50>
