[GRASS-dev] [GRASS GIS] #1703: wxGUI vector and raster querying
GRASS GIS trac at osgeo.org
Wed Aug 22 06:39:44 PDT 2012
 Reporter:  wenzeslaus   |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 The current state of map querying in wxGUI is not sufficient and some
 general solution (from user point of view) is needed.
 Wider discussion is necessary but there are some known problems already.
 Several inconsistencies and problems:
  * different text formatting for vector and raster
  * for vector map with db table dialog is displayed but for map without
 only v.what output is printed
  * vector attribute dialog is editable
  * coordinates are displayed only sometimes
  * for vector map with some layers with db table and some without, only
 layers with are displayed
 Highly related tickes:
  * #251 Enhancements to vector querying
  * #304 quering disables vector transparency
  * #523 wxGUI: querying a vector map in edit mode does nothing
  * #547 Raster query in wxGUI
  * #951 Error querying rasters in wxgui
  * #1402 Allow input coordinates to v.what to create a bounding rectangle
 for querying
  * #1469 wxgui vector query doesn't work for maps without attribute table
  * #1522 dbm_base.py fails with multilayer maps
  * #1606 attribute query tool reports "nothing found" when clicking on a
 vector object
  * #1607 attribute query fails to display text attribute values
  * #1608 WXGUI attribute query might lead to accidental attribute data
 editing
  * #1609 WXGUI doesn't offer a supported encodings for "Attribute data
 encoding" setting
 Other related tickets:
  * #281 query tool crashes when the user presses mouse buttons fast
  * #650 No warning when querying grid layer
  * #897 WinGrass: error with "Query vector map (edit mode)"
  * #941 add a query coordiantes under current cursor position
  * #1651 Map display Query Vector tool fails
Ticket URL: <http://trac.osgeo.org/grass/ticket/1703>
