[GRASS-dev] [GRASS GIS] #580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
trac at osgeo.org
Wed Aug 22 14:20:54 PDT 2012
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment(by mmetz):
Replying to [comment:50 glynn]:
> Replying to [comment:43 mmetz]:
> > WinGRASS is currently compiled against osgeo4w python and related
packages,
> WinGRASS isn't "compiled" against any version of Python.
OK, but GRASS is compiled "with" a particular Python version, for ctypes.
And apparently wxversion is needed which is only available in a devel
package (Linux).
> > > Adding .PY to the PATHEXT environment variable allows Python scripts
to be run without the extension (in the same way as .bat, .cmd, etc). That
will work for anything which uses the shell (system(), Python's subprocess
module, batch files, etc).
> > Even if the system knows nothing about any python.exe?
> If the .py extension hasn't been associated with a Python interpreter,
executing Python scripts won't work, with or with the .py extension.
> If we don't want to spend the rest of our lives adding one hack after
another to deal with Python scripts on Windows, "executing" a Python
script (via !CreateProcess(), system(), subprocess.Popen() or whatever)
has to just work, which requires that the .py extension is associated with
a working Python interpreter.
Should the existence of a working Python interpreter thus be the
responsibility of the user? Should we therefore remove the bundled python
from the wingrass installer? Because we do not want to interfere with an
existing Python installation, we either do not include an official Python
installer, or we do, but check first if any Python is already installed on
the system.
According to Helmut's report [comment:48] on the registry settings, I can
not see any trace of the Python versions coming with Inkscape and
!LibreOffice, but only of the Python version coming with ArcGIS.
To phrase it provocatively, do we want to go the ESRI way or do we want to
go the Inkscape and !LibreOffice way?
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/580#comment:51>
