[GRASS-dev] [GRASS GIS] #1087: wxGUI: Load multiple maps
    trac at osgeo.org
    Thu Aug 23 10:35:27 PDT 2012
  Reporter:  neteler      |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  6.5.0
 Component:  wxGUI        |     Version:  unspecified
Resolution:  fixed        |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Closing as fixed.
 wxGUI (in both 6 and 7) has now 'Add multiple raster or vector...' button
 in toolbar. Selection (filtering) is based on regular expression. Shortcut
 is Ctrl+Shift+L.
 Possible enhancements (create new ticked if you want them):
  * Selection done by Ctrl, Shift and mouse. (Now done by checkboxes. Maybe
 checkboxes fits better to regular expression based filtering.)
  * Selection (filtering) done expression containing wildcards similar to
 bash (e.g. use '*' (wildcard) instead of '.*' (regular expression))
  * Simplify the selection of vector (and 3D rasters) by different buttons,
 separated menu entries or by using the recently used value. (Now type
 raster is always the default choice.)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1087#comment:2>
