[GRASS-dev] [GRASS GIS] #1702: column selector for v.distance in wxGUI doesn't work
trac at osgeo.org
Fri Aug 24 13:50:29 PDT 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.4
Component: wxGUI | Version: unspecified
Keywords: column select | Platform: Unspecified
Cpu: Unspecified |
Changes (by wenzeslaus):
* milestone: 6.4.3 => 6.4.4
Comment:
This probably requires changes to g.parser and this will not happen now,
changing milestone.
As a temporary solution, I would suggest that combobox (drop down
selector) can be changed to simple text input field. This could avoid
confusion of the user.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1702#comment:3>
