[GRASS-dev] [GRASS GIS] #1711: Plot settings in profiler now broken
GRASS GIS trac at osgeo.org
Sat Aug 25 08:55:08 PDT 2012
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  critical     |   Milestone:  6.4.3
Component:  Default      |     Version:  svn-releasebranch64
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by annakrat):
 I can't reproduce this error. However I can see some inconsistency in the
 settings - when you change value (color, text) of certain widgets the
 change is automatically applied on the graph. But this doesn't work for
 all widgets. When the dialog has Apply button, these changes should apply
 only after clicking on the button and not earlier.
 After pressing Save you get this output in console: Plot settings saved to
 file 'None'.
 The settings file is changed but I cannot see the changed values.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1711#comment:5>
