[GRASS-dev] [GRASS GIS] #1615: Regression - v.transform fails to create a 3D map, crashes on Windows
GRASS GIS trac at osgeo.org
Sun Aug 26 06:50:19 PDT 2012
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.3
Component:  Vector       |     Version:  6.4.2
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mmetz):
 Replying to [comment:11 hellik]:
 > Replying to [comment:10 mmetz]:
 > > Tested here on XP with the wingrass 6.4.svn standalone installer
 r52917, should be the same like yours, but it works. No crash, no coor
 mismatch, all 10 points have been transformed, and bottom and top make
 sense, i.e. are identical to min and max in the h column.
 > > Markus M
 > now tested with the standalone WinGRASS-6.4.3svn-r52917-329-Setup.exe;
 no crash and no coor mismatch also here, but it seems no 3D output.
 Weird.
 > any idea why there are differences between osgeo4w-wingrass and
 standalone-wingrass on the same machine and obviously between different
 windows versions?
 Unfortunately no. I tried to test on a Windows 7 64 bit box, but I can not
 start GRASS because
 "Der Prozedureinsprungpunkt "sqlite3_open_v2" wurde in der DLL
 "sqlite3.dll" nicht gefunden."
 Now that is even weirder because GRASS does not use sqlite3_open_v2,
 instead it uses sqlite3_open which apparently works, but sqlite3_open
 calls sqlite3_open_v2 which does not work.
 Please do not respond to this comment within this ticket because this
 sqlite issue should be a separate ticket. I am investigating.
 Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/1615#comment:12>
