[GRASS-dev] [GRASS GIS] #1651: Map display Query Vector tool fails
GRASS GIS trac at osgeo.org
Mon Aug 27 00:03:01 PDT 2012
  Reporter:  vincent  |       Owner:  grass-dev@…
      Type:  defect   |      Status:  closed
  Priority:  normal   |   Milestone:  6.4.3
 Component:  wxGUI    |     Version:  svn-releasebranch64
Resolution:  fixed    |    Keywords:  query, vector
  Platform:  Linux    |         Cpu:  Unspecified
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:4 vincent]:
 > Ok, it works but... (sorry for quibbling) : query tool detects sql-
 filtered objects too. Is it a desirable behavior ? or should hidden
 features be unrequestable ?
 wxGUI uses v.what module for querying and v.what doesn't have 'where
 condition' parameter. But probably can have. At least for wxGUI it makes
 sense.
 If you want this implemented, please create new ticket. I would suggest
 you to create one enhancement for v.what (where condition parameter) and
 one defect for wxGUI (querying vector map displayed with where condition
 parameter).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1651#comment:5>
