[GRASS-dev] GRASS-user] command dialog notebook styles
Michael Barton Michael.Barton at asu.edu
Mon Aug 27 09:45:34 PDT 2012
On Aug 27, 2012, at 12:08 AM, Anna Kratochvílová wrote:
> Hi Michael,
> I hope you don't mind adding this discussion to mailing list.
No problem if you are OK with it.
> On Mon, Aug 27, 2012 at 12:15 AM, Michael Barton <Michael.Barton at asu.edu> wrote:
>> These look nice. I will try to test late in the week when I have time to
>> recompile.
>> A couple thoughts.
>> Multiple options like this give users more flexibility for customizing the
>> look of the program. And if it solves the hidden tab problem, that can be a
>> benefit to use. On the other hand, adding too many options adds more
>> complexity to an already very very complex GUI code, with more opportunities
>> for something to go wrong.
> Once the initial bugs are fixed (I hope there are not many) the code
> should be quite stable because all notebooks have very similar or
> identical API so   in the code you just switch classes representing
> the notebook styles and that's all.
That's good to hear. With probably >100K lines of code in the GUI (a guess that may way under count), I get worried about this.
>> The other thing to think about is that there is an advantage to having a
>> consistent GRASS brand and look across all platforms. That was the idea
>> behind the gradient green bar behind the tabs. (I forget who first suggested
>> flatnotebook, but I liked them because they were distinctive and not as
>> 'boring' as the normal rectangular ones that are on almost all other apps).
>> Perhaps  there are better ways of switching pages than flatnotebook style.
>> Having the tabs go down the left may be better for example, though it makes
>> dialogs wider and hence eats up more screen real estate. Anyway, after some
>> experimentation, even if switching to a new tab style there is some benefit
>> to settling on a standard style that is the GRASS brand.
>> Can flatnotebook do tabs on the left?
> I'am afraid that it is not possible.
> The point is to let the user choose what he wants. The current tabs
> don't look boring but I'm sure a lot of people would prefer standard
> 'boring' notebook. And still there is the issue with the hidden tabs
> which can be very confusing for not experienced user. Another question
> is which style should be the default one, if the nice but little
> confusing or the standard one?
Exactly. While we might want to keep the choices, we ought to have a default one that says 'GRASS' in its design somehow, but at the same time is not so baroque that it is not easy to use.
> Thanks for comments,
Certainly. I and many others very much appreciate your and Martin's continued work on the GUI.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
