[GRASS-dev] command dialog notebook styles
Anna Kratochvílová
kratochanna at gmail.com
Mon Aug 27 09:54:59 PDT 2012
One more question, all the tabs are empty? Command output and manual
tab are created separately so there could be some difference.
Thanks,
Anna
On Mon, Aug 27, 2012 at 6:52 PM, Anna Kratochvílová
<kratochanna at gmail.com> wrote:
> On Mon, Aug 27, 2012 at 5:52 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
>>>is there any related wiki-page, where screenshots (i.e. windows, etc.) can
>> be uploaded?
>> tested here in osgeo4w-wingrass7 in a win7-64bit-box.
>> only listleft works, in the other two no input is possible.
> That's bad. I am not able to test it. Are you able to switch the tabs?
> Maybe it's some problem with refreshing. I tried to google some
> windows specific problems with wx.Notebook but I haven't found
> anything interesting.
> The current fancy style works ok, is it right?
> I will wait if the similar problem occurs on Mac to (Michael promised to test)
> Thanks for testing,
> Anna
>> Helmut
>> http://osgeo-org.1560.n6.nabble.com/file/n4998104/notebookstyle_windows_listleft.png
>> http://osgeo-org.1560.n6.nabble.com/file/n4998104/notebookstyle_windows_basictop.png
>> http://osgeo-org.1560.n6.nabble.com/file/n4998104/notebookstyle_windows_basicleft.png
>> Helmut
>> best regards
>> Helmut
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/command-dialog-notebook-styles-tp4997929p4998104.html
>> Sent from the Grass - Dev mailing list archive at Nabble.com.
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
