[GRASS-dev] [GRASS GIS] #1615: Regression - v.transform fails to create a 3D map, crashes on Windows
GRASS GIS trac at osgeo.org
Mon Aug 27 23:06:27 PDT 2012
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  6.4.3
Component:  Vector       |     Version:  6.4.2
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by hellik):
 Replying to [comment:21 mmetz]:
 > AFAIK, quotes are only needed if the answer contains whitespace, and
 then also only on the command line, not the GUI. Update the manual?
 maybe an update of the manual, because columns="zshift:h" doesn't work
 neither in the wxgui-command line nor in the v.transform-gui.
 Helmut
 p.s. tested today osgeo4w-wingrass6.4.3svn-r52935 several times, no crash,
 no coormismatch, correct 3D output
Ticket URL: <http://trac.osgeo.org/grass/ticket/1615#comment:22>
