[GRASS-dev] [GRASS GIS] #151: make documentation be full text searchable: use sphinx
trac at osgeo.org
Wed Aug 29 00:56:07 PDT 2012
Reporter: timmie | Owner: epatton
Type: enhancement | Status: assigned
Priority: major | Milestone: 7.0.0
Component: Website | Version: unspecified
Keywords: | Platform: Unspecified
Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:32 glynn]:
> The output of the --interface-description switch has a well-defined
format, so the relevant information can readily be extracted from the
generated HTML file e.g. using a Python script based upon
tools/g.html2man/html.py.
While well defined, it is much easier and not that invasive to directly
render the
module parameters/flags descriptions in ReST.
> IMHO, it's preferable to cluttering up the build system with ReST-
specific features.
A Makefile guru may well see that the current approach could be simplified
(rather than ditched).
The usage of Sphinx offers capabilities we cannot achieve in a different
way
from the current HTML documentation. And the current HTML core pages will
remain as before, just an additional output is rendered:
HTML core page (as present) --+
g.parser --> HTML --------.---+---> HTML as currently
g.parser --> REST ------------+---> pandoc ---> Sphinx ---> additional
alternative
HTML with
search
Ticket URL: <https://trac.osgeo.org/grass/ticket/151#comment:33>
