[GRASS-dev] [GRASS GIS] #386: Thematic grouping of grass modules in the command line
GRASS GIS trac at osgeo.org
Wed Aug 29 02:25:04 PDT 2012
  Reporter:  nikos        |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  minor        |   Milestone:  7.0.0
 Component:  Docs         |     Version:  svn-trunk
Resolution:  fixed        |    Keywords:  grouping grass modules
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment(by hamish):
 Hi there,
 How about splitting it up into 3 columns?
 To get the balance correct it would have to know the number of elements in
 the list before it began writing the page.
 If you sorted alphabetically by row first, maybe you don't have to know
 that before hand, just do a 'carriage return' maneuver after every n'th
 column, then pad empty cells at the end of the table as needed.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/386#comment:11>
