[GRASS-dev] [GRASS GIS] #115: r.statistics: allow output to file and frequency count
trac at osgeo.org
Wed Aug 29 04:26:13 PDT 2012
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Resolution: wontfix | Keywords:
Platform: Unspecified | Cpu: Unspecified
Comment(by mlennert):
Replying to [comment:6 mmetz]:
> Replying to [comment:5 mlennert]:
> > I understand the logic and am closing this ticket as wontfix. I guess
what I was looking for would be more an enhancement of r.stats / r.reports
to provide different types of statistics of a cover map for different
categories of a base map (e.g. what is the range, stdev, min, max,
whatever of elevation in class 1 of my landcover map ?).
> Some of that can be done with r.univar which also allows output to file.
I am not sure if this is what you mean.
Wow, once again a functionality which has been in the code for almost 2
years without me noticing. GRASS never ceases to surprise...
(In case others are looking for the functionality: it's the 'zones'
parameter present since 6.4.2).
Thanks !
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/115#comment:7>
