[GRASS-dev] possible problem with r.terraflow
Michael Barton Michael.Barton at asu.edu
Thu Aug 30 21:07:56 PDT 2012
I just tried updating and compiling GRASS 6.4 svn and got an error compiling r.terraflow. It could be because I am still working out how to compile on Apple OSX 10.8 (Mt. Lion), but the rest of 6.4.3 compiled without errors. I'll list the error here. If this is really a bug, I can file a report.
Michael
=========== r.terraflow error ============
Michaels-MacBook-Air:r.terraflow cmbarton$ make
c++ -c -I/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin12.1.0/include  -arch i386 -isysroot /Developer/SDKs/MacOSX10.6.sdk   -DUSER=\"cmbarton\" -DNODATA_FIX -D_FILE_OFFSET_BITS=64   -DPACKAGE=\""grassmods"\" -DELEV_FLOAT main.cc -o OBJ.x86_64-apple-darwin12.1.0/FLOAT/main.o
In file included from main.cc:39:
In file included from ./common.h:27:
In file included from /Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/ami.h:39:
In file included from /Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/empq_impl.h:26:
In file included from /Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/empq.h:33:
/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/embuffer.h:1123:56: error:
      default arguments cannot be added to an out-of-line definition of a member
      of a class template
long em_buffer<T,Key>::insert(AMI_STREAM<T>* str, long bos=0) {
In file included from /Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/empq.h:35:
/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin12.1.0/include/grass/iostream/minmaxheap.h:494:7: error:
      reference to non-static member function must be called; did you mean to
      call it with no arguments?
  if (size) {
main.cc:181:16: warning: format string is not a string literal
      (potentially insecure) [-Wformat-security]
        G_fatal_error(_("Unable to create temp dir"));
/Users/Shared/grass_dev/grass64_rb/dist.x86_64-apple-darwin12.1.0/include/grass/glocale.h:10:16: note:
      expanded from macro '_'
#define _(str) G_gettext(PACKAGE,(str))
main.cc:191:15: warning: format string is not a string literal
    G_warning(_("The '-q' flag is superseded and will be removed "
main.cc:367:19: warning: format string is not a string literal
    G_fatal_error(_("cannot read range"));
main.cc:389:19: warning: format string is not a string literal
    G_fatal_error(_("cannot write colors"));
main.cc:407:19: warning: format string is not a string literal
main.cc:414:19: warning: format string is not a string literal
main.cc:434:44: warning: format specifies type 'int' but the argument has type
      'unsigned long' [-Wformat]
  G_message( "\t\t FILL: %s [%d elements, %dB each]",
                                          %ld
main.cc:437:45: warning: format specifies type 'int' but the argument has type
  G_message( "\t\t FLOW: %s [%ld elements, %dB each]",
                                           %ld
8 warnings and 2 errors generated.
make: *** [OBJ.x86_64-apple-darwin12.1.0/FLOAT/main.o] Error 1
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20120831/bea0d19a/attachment-0001.html>
