[GRASS-dev] why is r.li.setup unavailable in GRASS 7?
Anna Kratochvílová
kratochanna at gmail.com
Sat Dec 1 05:54:45 PST 2012
On Sat, Dec 1, 2012 at 2:09 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> 2012/12/1 Michael Barton <Michael.Barton at asu.edu>:
>> Luca,
> Hi Micheal
>> r.li.setup does not yet compile in GRASS 7, at least on the Mac.
> I'm sorry :-(
>> Here is the error:
>> anthgradpc7:g.version cmbarton$ cd /Users/Shared/grass_dev/grass7_dev/gui/wxpython/rlisetup
>> anthgradpc7:rlisetup cmbarton$ make
>> if [ "/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.rlisetup" != "" ] ; then GISRC=/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/demolocation/.grassrc70 GISBASE=/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0 PATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/bin:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/bin:$PATH" PYTHONPATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/etc/python:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/etc/python:$PYTHONPATH" DYLD_LIBRARY_PATH="/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/bin:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/lib:/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/lib:" LC_ALL=C /Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.rlisetup --html-description < /dev/null | grep -v '</body>\|</html>' > g.gui.rlisetup.tmp.html ; fi
>> Traceback (most recent call last):
>> File "/Users/Shared/grass_dev/grass7_dev/dist.x86_64-apple-darwin12.2.0/scripts/g.gui.rlisetup", line 32, in <module>
>> import wx
>> File "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/__init__.py", line 45, in <module>
>> from wx._core import *
>> File "/usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core.py", line 4, in <module>
>> import _core_
>> ImportError: /usr/local/lib/wxPython-unicode-2.8.12.1/lib/python2.7/site-packages/wx-2.8-mac-unicode/wx/_core_.so: no appropriate 64-bit architecture (see "man python" for running in 32-bit mode)
>> make: *** [g.gui.rlisetup.tmp.html] Error 1
>> rm g.gui.rlisetup.tmp.html
> This seems more a WX problem...I know that it's a "stupid" answer but
> could you try
> import wx
> from python console?
>> This may be the same error that is now affecting several GUI modules like map swipe, animation, and the graphical modeler.
Just a remark:
This problem affecting map swipe, animation, graphical modeler and
r.li.setup is spread in several threads which makes it more
complicated to follow. What about to choose one of them?
subjects:
compiling animation, mapswipe, etc.
problems compiling GRASS 7 on Mac
Compiling under OSX Mountain Lion
Best,
Anna
>> Michael
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
