[GRASS-dev] GRASS 6.4.3 release planning; v.external 3D
Benjamin Ducke
benducke at fastmail.fm
Sun Dec 2 03:24:24 PST 2012
>>> And the ability to use v.external with 3D data
>>> sources.
>> Please try attached v.external64_3D.diff.
> That looks good. I will try this (i.e. the
> current SVN snapshot) with some 3D data and
> report back.
From what I can tell, 3D vertices are read
correctly by v.external now, and the data's Z
extent is also set correctly. Great.
Would it be possible to implement the same
behaviour in v.in.ogr, i.e. have it auto-
matically read Z data from 3D sources, instead
of having to set the "-z" flag manually?
Or would that change the expected behaviour too
much for a 6.4.x release?
Cheers,
Ben
> Cheers,
> Ben
>> Markus
Benjamin Ducke
{*} Geospatial Consultant
{*} GIS Developer
