[GRASS-dev] Error compiling GRASS 7 on Windows - Unknown platform i686-pc-msys
Helmut Kudrnovsky
hellik at web.de
Mon Dec 3 11:23:27 PST 2012
>It appears that "uname -s" refers to "msys" rather than "mingw".
>I've made the following change in r54167:
now I get:
Mon Dec 3 19:21:37 GMT 2012: STARTING remove old logs
Mon Dec 3 19:21:38 GMT 2012: FINISHED remove old logs AFTER 1s
Mon Dec 3 19:21:38 GMT 2012: STARTING configure
checking host system type... i686-pc-msys
checking for gcc... gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for Cygwin environment... no
checking for mingw32 environment... yes
checking for executable suffix... .exe
checking for full floating-point support... yes
checking for pwd... /bin/pwd
checking for source directory... /osgeo4w/usr/src/grass_trunk
checking for build directory... /osgeo4w/usr/src/grass_trunk
checking for svnversion... no
checking for MacOSX App... no
checking for MacOSX architectures... no
checking for MacOSX SDK... no
checking how to build libraries... shared
./configure: line 1507: syntax error near unexpected token `)'
./configure: line 1507: ` *-pc-msys)'
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-compiling-GRASS-7-on-Windows-Unknown-platform-i686-pc-msys-tp5020437p5020455.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
