[GRASS-dev] [GRASS GIS] #1820: WinGRASS -- Multiple Map Display Lockup?
trac at osgeo.org
Mon Dec 3 18:19:46 PST 2012
Reporter: ianhawboldt | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: unspecified
Keywords: | Platform: MSWindows XP
Cpu: x86-32 |
WinGRASS 6.4.3-svn-r54145-429
Windows XP, SP3
If I load a vector poly layer into the "Display 1" tab, and then create a
"New map display", and load another vector poly layer into the "Display 2"
tab, then I have two maps in the same mapset which can be displayed side-
by-side. Well and good...
If I then save this "dual-display" workspace, exit completely from GRASS,
and then re-enter, and then try to load this newly-created workspace,
everything "locks up" -- that is to say:
(1) No poly layers are displayed in the "Display 1 Map".
(2) No poly layers are displayed in the "Display 2 Map".
(3) Display 2 is locked -- I can't click on Display 1 and go back to it.
(4) A gray window displays the message "Please wait, loading workspace..."
and remains in view forever.
(5) I can't exit from GRASS if I select /File/Exit or CTRL-Q.
(6) I have to terminate the GUI "cmd-window" to get out of GRASS.
However, if I open this workspace from 6.4.2, then all is well -- both
maps are displayed side-by-side correctly. This in spite of the fact that
the new parameter "name=" was introduced in 6.4.3.
This is unfortunate, as I was hoping to use 6.4.3 in order to access the
fixed-up Table Manager -- oh well.....for now I am using both versions
back-and-forth as a workaround.
Apologies if this has been reported elsewhere, but I scrounged around in
the tickets and couldn't find anything close.
Thanks,
Ian Hawboldt
Ticket URL: <http://trac.osgeo.org/grass/ticket/1820>
