[GRASS-dev] [GRASS GIS] #1819: problems compiling map swipe, animation, modeler, and r.li.setup
trac at osgeo.org
Mon Dec 3 16:51:26 PST 2012
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Keywords: | Platform: MacOSX
Cpu: OSX/Intel |
Comment(by kyngchaos):
"type python" should verify which python is found first in your PATH. If
you run Python in the terminal with the PATH set, Activity Monitor shows
32/64bit mode of apps. These tell you what ''should'' happen in make, but
it's hard to check what really runs since python runs so quickly and quits
that you probably won't see it in Activity Monitor.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1819#comment:4>
