[GRASS-dev] [GRASS GIS] #1822: wxGUI location wizard imports 3D Shapefile as 2D
GRASS GIS trac at osgeo.org
Tue Dec 4 04:41:16 PST 2012
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Startup      |     Version:  svn-trunk
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
 When creating a new location based on a Shapefile, location wizard imports
 it into the new location, still it's done in 2D mode thus losing all Z
 coordinates of dataset.
 This is worse than not importing at all as when user is forced to use
 import module (v.in.ogr), it might notice -z option and enable it. Current
 behaviour might lead to data loss (delete shapefile without checking
 metadata in GRASS) or wrong conclusions that GRASS doesn't support 3D
 shapefiles (WRONG!).
Ticket URL: <http://trac.osgeo.org/grass/ticket/1822>
