[GRASS-dev] Error compiling GRASS 7 on Windows - Unknown platform i686-pc-msys
Tue Dec 4 08:16:11 PST 2012
lists at rtwilson.com wrote:
> Tue Dec 4 09:27:47 GMTST 2012: STARTING remove old logs
> Tue Dec  4 09:27:47 GMTST 2012: FINISHED remove old logs AFTER 0s
> Tue Dec 4 09:27:47 GMTST 2012: STARTING configure
> checking host system type... i686-pc-mingw32
> checking for gcc... gcc
> checking whether the C compiler (gcc  ) works... yes
> checking whether the C compiler (gcc  ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... rm: cannot lstat `conftest.exe':
> Permission denied
> yes
This suggests a problem with the build environment.
conftest.exe is the default name for any test programs which the
configure script generates.
You should examine the config.log file for related error messages.
