[GRASS-dev] [GRASS GIS] #1816: gui crashes when setting color table
trac at osgeo.org
Tue Dec 4 21:02:24 PST 2012
Reporter: rashadkm | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Keywords: wxgui, color table | Platform: Linux
Cpu: x86-64 |
Comment(by rashadkm):
r.info lsat_composite tells about the description
Data Description:
generated by r.composite
Can this be used to identify composite maps?
Another option is to issue a warning without showing colortable dialog
something like "no color table entry for the map because of composite etc"
The limit can be calculated using a MAX_COLOR_GROUP that can be set to
50/100 (or maximum color groups supported in existing rules) by default
Also MAX_COLOR_GROUP can be modified in setting by user
Hope this make sense
Ticket URL: <http://trac.osgeo.org/grass/ticket/1816#comment:4>
