[GRASS-dev] g.extension not working on debian - grass 6.4.3svn
Margherita Di Leo
dileomargherita at gmail.com
Thu Dec 6 10:20:29 PST 2012
Hi All,
I'm having issues in using g.extension and before filing a bug report I
should like to know whether am I not seeing anything obviously wrong from
my side.
GRASS 6.4.3svn (nc_spm_08):~ > g.extension extension=r.stream.extract
operation=add
Fetching <r.stream.extract> from GRASS-Addons SVN (be patient)...
A r.stream.extract/flag.h
A r.stream.extract/streams.c
A r.stream.extract/load.c
A r.stream.extract/del_streams.c
A r.stream.extract/local_proto.h
A r.stream.extract/thin.c
A r.stream.extract/rbtree.c
A r.stream.extract/main.c
A r.stream.extract/close.c
A r.stream.extract/description.html
A r.stream.extract/rbtree.h
A r.stream.extract/flag.c
A r.stream.extract/Makefile
A r.stream.extract/do_astar.c
U r.stream.extract
Checked out revision 54224.
Compiling <r.stream.extract>...
/usr/local/grass-6.4.3svn/include/Make/Grass.make:423: warning: overriding
commands for target
`/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin'
/usr/local/grass-6.4.3svn/include/Make/Grass.make:414: warning: ignoring
old commands for target
/usr/local/grass-6.4.3svn/include/Make/Module.make:25: warning: overriding
commands for target `install'
/usr/local/grass-6.4.3svn/include/Make/Rules.make:99: warning: ignoring old
mkdir -p
mkdir -p
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include/grass
mkdir -p
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/etc
mkdir -p
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/driver
mkdir -p
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/driver/db
mkdir -p
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/fonts
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p
gcc '-I/usr/local/grass-6.4.3svn/include'
'-I/home/madi/.grass6/addons/include'
'-I/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/include'
-g -Wall -I/usr/local/include -I/usr/local/include
-DPACKAGE=\""grassmods"\" '-I/usr/local/grass-6.4.3svn/include'
-o OBJ.x86_64-unknown-linux-gnu/close.o -c close.c
-o OBJ.x86_64-unknown-linux-gnu/del_streams.o -c del_streams.c
-o OBJ.x86_64-unknown-linux-gnu/do_astar.o -c do_astar.c
-o OBJ.x86_64-unknown-linux-gnu/flag.o -c flag.c
-o OBJ.x86_64-unknown-linux-gnu/load.o -c load.c
-o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
-o OBJ.x86_64-unknown-linux-gnu/rbtree.o -c rbtree.c
-o OBJ.x86_64-unknown-linux-gnu/streams.o -c streams.c
-o OBJ.x86_64-unknown-linux-gnu/thin.o -c thin.c
gcc '-L/usr/local/grass-6.4.3svn/lib' '-L/home/madi/.grass6/addons/lib'
'-L/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/lib'
-Wl,--export-dynamic -Wl,-rpath-link,/usr/local/grass-6.4.3svn/lib
-L/usr/include/postgresql/libpq/ -o
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin/r.stream.extract
OBJ.x86_64-unknown-linux-gnu/do_astar.o OBJ.x86_64-unknown-linux-gnu/flag.o
OBJ.x86_64-unknown-linux-gnu/load.o OBJ.x86_64-unknown-linux-gnu/main.o
OBJ.x86_64-unknown-linux-gnu/streams.o OBJ.x86_64-unknown-linux-gnu/thin.o
-lgrass_vect.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn
-lgrass_datetime.6.4.3svn -lz -lgrass_dbmiclient.6.4.3svn
-lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn
-lz -lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz
-lgrass_dgl.6.4.3svn -lgrass_dig2.6.4.3svn -lgrass_gis.6.4.3svn
-lgrass_datetime.6.4.3svn -lz -lgrass_rtree.6.4.3svn
-lgrass_linkm.6.4.3svn -lgrass_rtree.6.4.3svn -lgrass_dig2.6.4.3svn
-lgrass_rtree.6.4.3svn -lgrass_dgl.6.4.3svn -lgrass_rtree.6.4.3svn
-lgrass_linkm.6.4.3svn -lgrass_dbmiclient.6.4.3svn
-lz -L/usr/local/lib -lgdal -L/usr/local/lib -lgeos -lgeos_c
-lgrass_dbmiclient.6.4.3svn -lgrass_dbmibase.6.4.3svn -lgrass_gis.6.4.3svn
-lgrass_datetime.6.4.3svn -lz -lgrass_gis.6.4.3svn
-lgrass_datetime.6.4.3svn -lz -lgrass_dbmibase.6.4.3svn
-lgrass_gis.6.4.3svn -lgrass_datetime.6.4.3svn -lz -lm -lz
make htmlcmd
make[1]: Entering directory
`/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/r.stream.extract'
commands for target
make
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/docs/html/r.stream.extract.html
HTMLSRC=/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin/r.stream.extract
make[2]: Entering directory
commands for target
if [
"/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin/r.stream.extract"
!= "" ] ; then
GISRC=/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/demolocation/.grassrc64
GISBASE=/usr/local/grass-6.4.3svn
PATH="/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin:$PATH"
LD_LIBRARY_PATH="/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/bin:/usr/local/grass-6.4.3svn/lib:/usr/local/grass-6.4.3svn/lib"
LC_ALL=C
--html-description < /dev/null | grep -v '</body>\|</html>' >
r.stream.extract.tmp.html ; true ; fi
/usr/local/grass-6.4.3svn/tools/mkhtml.sh r.stream.extract ; mkdir -p
; /usr/bin/install -c -m 644 r.stream.extract.tmp.html
; for file in *.png *.jpg ; do head -n 1 $file | grep '^#!' > /dev/null ;
if [ $? -ne 0 ] ; then /usr/bin/install -c -m 644 $file
; fi done 2> /dev/null ; true
make[2]: Leaving directory
make[1]: Leaving directory
make mancmd
commands for target
make
/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/man/man1/r.stream.extract.1
MANSRC=/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/docs/html/r.stream.extract.html
commands for target
mkdir -p
GRASS_PERL=/usr/bin/perl VERSION_NUMBER=6.4.3svn sh
/usr/local/grass-6.4.3svn/tools/g.html2man
1
make[2]: ***
[/home/madi/grassdata/nc_spm_08/testing/.tmp/amylee/3538.0/dist.x86_64/man/man1/r.stream.extract.1]
Error 127
make[1]: *** [mancmd] Error 2
make: *** [cmd] Error 2
ERROR: Compilation failed, sorry. Please check above error messages.
Thanks in advance for any hint..
cheers
madi
Margherita DI LEO
Postdoctoral Researcher
European Commission - DG JRC
Forest Resources and Climate
I-21020 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo at jrc.ec.europa.eu
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121206/0c0e63da/attachment-0001.html>
