[GRASS-dev] tgis.db
Sören Gebbert
soerengebbert at googlemail.com
Sat Dec 8 04:07:36 PST 2012
Hi Martin,
sorry i am confused. I made a svn update of grass trunk and typed
db.connect help.
The default path there is: "$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db".
I have had chosen the same path for the temporal GIS database. Has
this changed recently?
Is this really needed? If i change the default tgis.db path i need to
assure backward compatibility to avoid damage on existing temporal
GRASS locations.
Best regards
Soeren
2012/12/8 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2012/12/8 Sören Gebbert <soerengebbert at googlemail.com>:
>> why would it be better to put this single file in a separate directory?
> because it's default 'database' for SQLite driver, see `db.connect`.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
