[GRASS-dev] tgis.db
Sören Gebbert
soerengebbert at googlemail.com
Sat Dec 8 04:25:39 PST 2012
2012/12/8 Martin Landa <landa.martin at gmail.com>:
>> default database [1]. Default DB for SQLite driver has been changed in
>> r52829 [2].
> looking at the comment (see the [2]), I am not sure if it's a good
> idea to have more SQLite DBs in one directory. Probably MarkusM could
> elaborate on that...
I see, sqlite is fsyncing its directory. So it may not be a good idea
to have two sqlite databases in the same directory
or in nested sub-directories.
Maybe its a better idea to use a separate directory like tgis or temporal?
$GISDBASE/$LOCATION_NAME/$MAPSET/tgis/tgis.db
$GISDBASE/$LOCATION_NAME/$MAPSET/temporal/tgis.db
Best regards
Soeren
> Martin
> [1] http://trac.osgeo.org/grass/changeset/52829/grass/trunk/lib/db/dbmi_base/default_name.c
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
