[GRASS-dev] [GRASS GIS] #1831: wxgui d.vect: layer option should show default applied (1), not -1
trac at osgeo.org
Tue Dec 11 07:04:59 PST 2012
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.3
Component: wxGUI | Version: 6.4.2
Keywords: d.vect | Platform: Unspecified
Cpu: Unspecified |
The d.vect gui in the wxgui shows -1 by default for the layer parameter.
However, the default in grass6 is 1. This creates confusion for the user.
Is there a way to have the layer option in the GUI show the actual default
value ?
This might be more generic than the specific case of d.vect and layers. I
just happened to notice it here since my students were very confused after
using v.net to connect nodes to a network to then not see those nodes,
even though the layer option showed -1 in the GUI.
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1831>
