[GRASS-dev] [GRASS GIS] #1831: wxgui d.vect: layer option should show default applied (1), not -1
GRASS GIS trac at osgeo.org
Wed Dec 12 04:27:12 PST 2012
 Reporter:  mlennert     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.3
Component:  wxGUI        |     Version:  6.4.2
 Keywords:  d.vect       |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by marisn):
 Just tested with a fresh svn up && distclean && make on trunk r54265 and
 the issue #1749 with GUI/executed command mismatch is still present. I
 would assume it might have the same root cause as for this issue somewhere
 in d.vect wxGUI layer switching magic code.
 Replying to [comment:2 mlennert]:
 > Replying to [comment:1 marisn]:
 > > Could be related to #1749 ?
 > Possibly, although I cannot reproduce #1749 on either 6.4.2, 64release
 or trunk. Which version are you using to produce this ?
 > Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/1831#comment:3>
