[GRASS-dev] [Qgis-developer] GRASS Direct
Markus Neteler
neteler at osgeo.org
Thu Dec 13 13:39:04 PST 2012
On Mon, Dec 10, 2012 at 10:02 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> FYI from the qgis-dev-ML:
> http://lists.osgeo.org/pipermail/qgis-developer/2012-December/023640.html
> ______________________________
> The GRASS Direct is an environment developed within QGIS GRASS
> plugin/provider which makes it possible to run GRASS raster modules
> without GRASS mapset and without data conversion to GRASS format.
> Basically it is a library implementing GRASS data read/write function
> which is using QGIS providers to read/write data. In direct mode, the
> GRASS modules are run with this library instead of the standard GRASS
> gis library.
Cool stuff, congrats, Radim!
Markus
