[GRASS-dev] Use of g.proj in r.tileset
Markus Neteler
neteler at osgeo.org
Fri Dec 14 05:08:32 PST 2012
On Thu, Dec 6, 2012 at 11:39 AM, Paulo van Breugel
<p.vanbreugel at gmail.com> wrote:
> Hi
> In the helpfile for r.tileset (GRASS 70), the following example is given:
> r.tileset sourceproj=`g.proj -j location=IrishGrid` maxrows=400 maxcols=300
> overlap=3 -g
> For me this only works when using double quotes around the g.proj command
> r.tileset sourceproj="`g.proj -j location=IrishGrid`" maxrows=400
> maxcols=300 overlap=3 -g
> I am using grass 70 on Ubuntu 12.10. Is this something specific to the type
> of shell used?
IMHO you are right, I have fixed the example.
thanks
Markus
