[GRASS-dev] r.digit
Mohammed Rashad mohammedrashadkm at gmail.com
Sun Dec 16 21:10:57 PST 2012
On Mon, Dec 17, 2012 at 9:06 AM, Hamish <hamish_b at yahoo.com> wrote:
> Mohammed:
> > > Does r.digit needs to be ported or not?
> Vaclav:
> > Combination digitize vector + convert to raster is not able
> > to allow user to decide which particular cell should or should
> > not be digitized. So, the raster digitizer is needed for this.
> > But I don't know if this is a frequent case. I don't know
> > r.digit but it was the same as digitizer + v.to.rast according
> > to module description.
> Hi guys,
> G6's r.digit is a front end to the r.in.poly module, which takes
> an input not dissimilar to the v.in.ascii standard grass format.
> An old idea was to just reuse the wx digitizer tool but instead
> of writing to grass vector ascii format + v.in.ascii change
> things a little and save to r.in.poly ascii format instead.
> Since then the wx digitizer got way more advanced, I'm not sure
> if it is possible any more to just have an extra Save As.. in
> the file menu/toolbar. (I hope it is)
> for my 2c it's quite nice to have a dedicated raster digitizing
> option, instead of needing an extra v.in.ascii -> v.to.rast
> step in your workflow. That doesn't rule out a wrapper script
> to hide the vector part of it, but a dedicated r.in.poly mode
> would both be more efficient and perhaps less prone to loss in
> fidelity.
By dedicated raster digitizer you mean using r.in.poly or using C code +
cyptes wrapper for wxGui, the same way as wxDigitizer?
Btw, r.in.poly implementation is very easy!!. But I dont know about its
efficiency
> thanks,
> Hamish
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20121217/8e2f864c/attachment-0001.html>
