[GRASS-dev] [GRASS GIS] #1801: r3.in.ascii fails in GRASS6.4.3
trac at osgeo.org
Wed Dec 19 00:45:17 PST 2012
Reporter: helena | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.3
Component: Raster3D | Version: svn-releasebranch64
Keywords: r3.in.ascii, raster3d import | Platform: MacOSX
Cpu: OSX/Intel |
Description changed by neteler:
Old description:
> r3.in.ascii produces the following error in GRASS6.4.3svn compiled today
> GRASS 6.4.3svn (nc_spm_05):~ > r3.in.ascii JR_7408MR_2m3dtest.asci
> out=testr3inasci
> Loading data ... (570x594x8)
> ERROR: asciiToG3d: read failed
> running r3.info on the created (but broken) 3d raster shows that
> following command was used:
> r3.in.ascii input="JR_7408MR_2m3dtest.asci" output="testin3d" nv="no\ |
> | ne" type="default" precision="default" compression="default"
> tiledim\ |
> | ension="default"
> and running r3.in.ascii --help also shows that default value is the
> string default
> rather than a valid number. I tried to run it with some reasonable
> numbers but I got
> ERROR: Error getting standard parameters
New description:
out=testr3inasci
running r3.info on the created (but broken) 3d raster shows that following
command was used:
tiledim\ |
| ension="default"
and running r3.in.ascii --help also shows that default value is the string
default
rather than a valid number. I tried to run it with some reasonable numbers
but I got
Ticket URL: <http://trac.osgeo.org/grass/ticket/1801#comment:2>
